hello!
How good that this community has been created! I hope to be part of it! Maybe you can help me, I have experience with electronics and programming now I'm a bit lost with this problem ...
I have purchased my first arpschuino, with a card for steper motors. Arpschuino receives dmx and flashes green, great !, but the nema 17 motors are not moving ... they are blocked, so it receives load ...
I rule out possible problems, electronics ok, I have experience soldering cpb and fritzing, the 4988 driver is new, and I have tried several, correctly fed everything with 12v, the programming is ok, with the new nut (May 2021) in arpschuino and arpstepper example, where I edit address to include in programming, I attach code. I am using dmx enttec open usb to dmx, and VSA software that commands dmx
Problem with arpstepper, green led is ok, not run nema 17
adrian.laurel
Re: Problem with arpstepper, green led is ok, not run nema 17
Hello Adrian, welcome in the arpschuino community !
Looking at your code, I realize that you have defined 0 as DMX address:
The address must be set between 1 and 512 (more exactly, 512-the number of addresses used), it is true that in programming we are used to starting from zero but here it is the logic of the DMX which is used.
address=0;
