Arpschuino32 - servo angle not stored
Micropuller
Message par Micropuller »
I managed to assemble and setup my arpschuino32 today.
My main interest is to use it to drive stepper motors (which I hopefully be testing shortly).
I tried configuring the stepper settings and everything seems to be working fine.
But I also wanted to try the servo motor option.
Whilst configuring the servo's, it will let me change the "inverted" and "detach" options, but it won't store the servo angle.
After changing it to, for instance, 90 degrees, I click "OK" and reboot the board. But it always reverts to 180 degrees.
Edit:
I had port A configured for steppers and port B for servo's. I tried configuring port A for servo's and it did store the servo angle (but still not for port B).
Re: Arpschuino32 - servo angle not stored
hummm........ I just tried, I think you found a bug!!!!!
I will fix it quickly, in the meantime use portA.
Ok, it is fixed !
I just uploaded a corrective update.
I also fixed the trigger in port B on/off mode which had the same problem.
Congratulations and thank you for reporting the bugs, it helps us move forward and we try to be responsive.
To update see in the tool tab of the interface, in the field "update to version" type 1.0.1 and click on "Update!".
That's all !
https://arpschuino.fr/arpschuino32_firm ... ions_e.php
Micropuller
Hello Jaques,
Thanks for the quick fix!
For some reason my board won't update though.
I typed 1.0.1 in the "update to version" box and clicked the "update!" button.
First I got the message "Search this version", then "Checking firmware" and finally "Cannot download firmware file".
My computer is connected to the internet.
Strange...
Can you try a second time please ?
https://arpschuino.fr/update-arpschuino32_e.php
Micropuller
I'm sorry, but I get the same error.
I'm sorry too...
What happens when you click on the links at the bottom of the page?
Also, what happens when you type in your browser's address bar:
http://www.arpschuino.fr/firmware/arpsc ... e1.0.1.bin
and :
https://www.arpschuino.fr/firmware/arps ... e1.0.1.bin
What browser do you use?
Try another browser.
Micropuller
When I click the links, they take me to the website or the forum.
When I put the URL in the address bar, it downlaods a file called "firmware 1.0.1.bin"
I use Google Chrome as my browser.
